I have write an application in Visual Studio 2005 under WINCE 5. I can deploy it to the board. It is running fine. But when I power down and up the board all the files are gone. What is the problem?
DOWNLOAD WINCE APPLICATION
If I copy it in resident flash, when I try to run the application I get an error saying that it can not be run. An application is missing.
how r u copying? keep build mode in release and compile,then copy application file from \bin\Release to resident flash.
If you open your Application project's properties then there is a list down the left, click on Devices. There you can set the Output File Folder. Change it to something like \Resident Flash\MyApp or what ever...
Hello! If your application use NETCF 3.5 you must rebuild WINCE with platform builder that include NETCF 3.5, same operation for SQLCE and/or SQLClient library...
