Hello all Please, I need your help... I´m trying to measure a battery Li-Poly with the Mini 2440 in winCE5.0, But I don´t know how is the driver for use de ADC pin. How Can I make this? Which is the driver for sleep mode when the battery is low or press any button direclty to EINT (15:0)? Also, I would like to know about the schematic of this. Can you help me please. If I be not apropiate, Í´m sorry Regards Rodrigo
wince 5.0 battery management
Hey, Not sure about the support drivers for CE but I also would like to know where and if it is located in the catalog. Like Battery support like in Windows Mobile. Rodrigo you can connect the battery to the adc through a Voltage Divider configuration. Look it up and work it out. Make sure you test though as you can blow the board if to high. Zac
