Hello, Please help me, I success on complie Qt 4.5.3 and can run the demo program on mini2400 3.5 inch LCD. But when I switch to run on 7 inch LCD, it say "segment fault". On the mini 2440 7 inch LCD it can run Qtopia2.2 that install form the factory. Anyone has the idea to run the application on 7" LCD. Thankyou
Cannot run Qt demos on 7" LCD
Can you post the list of build steps followed for 4.5.3 to get the 3.5 lcd Iam struggling past 5 days to make it work with touch I need the following steps, 1. Tslib configuration steps 2. Qt-4.5.3 configure options , common/g++.conf,qws/qmake.conf 3. installation export macro needed in mini2440 board. ---------------------------- I build qt-4.5.3,qt-4.6.2,qt-4.6.1 and these packages iam able to move the cusor while touching the screen. but no response from application (example pushbutton when i touch mouse cursor moving to that position but events are not triggered) I think iam missing some export macros in mini2440....
The environment variable that I set for Tslib is export TSLIB_TSDEVICE='/dev/input/event0' export TSLIB_TSEVENTTYPE=input export TSLIB_CONSOLEDEVICE=none export TSLIB_FBDEVICE=/dev/fb0 export TSLIB_CONFFILE=/tslib/etc/ts.conf export TSLIB_PLUGINDIR=/tslib/lib/ts export TSLIB_CALIBFILE=/tslib/etc/pointercal and QWS variable is export QWS_CURSOR_ROTATION='0' export QWS_DISPLAY='LinuxFb' export QWS_KEYBOARD='TTY:/dev/tty1' export QWS_MOUSE_PROTO='tslib:/dev/input/event0
