Dumb Question, but has anyone attached a USB HDD to this board? the manual is .. vague.. If someone has - any ideas of transfer rates? Thanks!
USB HDD on mini2440?
I have done this. but I hvnt verified transfer rates. I only checked if I can attach my USB HDD. Currently it is formatted with NTFS, so i added support for NTFS in kernel and tested. later on I changed my mind and decided that i will use ext3. So needs to format the HDD and copy the data somewhere before formatting. If you really want this data, i can do this on priority. regards, Kailas
Not so important, it sounds like it wasn't horribly slow :) I'm looking for a replacement for my slug :)
Hi Kailas Can you elaborate how you added support for NTFS? My Mini2440 has 2.6.32 and am finding how to get support for NTFS USB HDD. Thanks in advance Satish
Satish, I have used following: CONFIG_NTFS_FS=y CONFIG_NTFS_DEBUG=y CONFIG_NTFS_RW=y Regards, Kailas
Thanks for your reply, Kailas Unfortunately this is not working. When connected, /udisk does not show anything. However on plugging in the USB HDD, following is diplayed on the terminal. Kernel is 2.6.32. Initially gave all the three CONFIG_s and then inserted USB HDD with NTFS. Please note same USB HDD when formatted FAT / FAT32 works fine. [root@FriendlyARM /]# CONFIG_NTFS_FS=y [root@FriendlyARM /]# CONFIG_NTFS_DEBUG=y [root@FriendlyARM /]# CONFIG_NTFS_RW=y [root@FriendlyARM /]# usb 1-1: new full speed USB device using s3c2410-ohci and address 3 usb 1-1: New USB device found, idVendor=067b, idProduct=2506 usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 usb 1-1: Product: Mass Storage Device usb 1-1: Manufacturer: Prolific Technology Inc. usb 1-1: SerialNumber: 00 usb 1-1: configuration #1 chosen from 1 choice scsi1 : SCSI emulation for USB Mass Storage devices scsi 1:0:0:0: Direct-Access TOSHIBA MK3021GAS GA12 PQ: 0 ANSI: 0 sd 1:0:0:0: Attached scsi generic sg0 type 0 sd 1:0:0:0: [sda] 58605120 512-byte logical blocks: (30.0 GB/27.9 GiB) sd 1:0:0:0: [sda] Write Protect is off sd 1:0:0:0: [sda] Assuming drive cache: write through sd 1:0:0:0: [sda] Assuming drive cache: write through sda: sda1 sd 1:0:0:0: [sda] Assuming drive cache: write through sd 1:0:0:0: [sda] Attached SCSI disk FAT: utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive! Please let me know if you have any clues. Thanks & best regards Satish
sathish, these parameters have to be set while compiling the kernel. You have to build your kernel with these parameters. regards, Kailas
Sathish, 1 more thing. above settings are for NTFS. if you need to access FAT partition then you need to set following: CONFIG_FAT_FS=y CONFIG_VFAT_FS=y CONFIG_FAT_DEFAULT_CODEPAGE=936 CONFIG_FAT_DEFAULT_IOCHARSET="utf8" regards, Kailas
Thanks Kailas. Can you please tell me where (in which file) I will have to put in those options? Do you mean if we need to have FAT, we should compile Kernel with FAT options and if we need to have NTFS, we should compile Kernel with NTFS options? Can we have both options? So that I will be able to access either of them, depending on which HDD (NTFS or FAT) I have plugged in at a particular moment? Sorry if these questions are very basic and irritating, I am a novice. Best regards Satish
Satish, Check your DVD which came along with the product. In that you will find kernel source. You have to copy that into your PC. Then copy the ARM cross compiler toolchain. you will also find some "config_mini2440*" files in the kernel source. Depending on the hardware(LCD) you have, you need to use the file. copy this file to ".config" in some other folder and then from kernel source directory run the command "make O=/your_config_file_directory". If you are still not sure, you can write a mail to me at kvshetye at yahoo dot com. regards, Kailas
Hello Kailas, As well as Baradhili, I would very interesting in seeing what transfer rates you get to/from your hardisk as i plan to use one of these boxes as a small NAS device. If you do find the time to test it please kindly post the results here :) Thanks, Will.
Hi Kailash I put in your patch CONFIG_NTFS_FS=y CONFIG_NTFS_DEBUG=y CONFIG_NTFS_RW=y in .config. Commented the same for FAT and then compiled and reloaded the kernel on mini2440. However it doesnot work. When configured for FAT, it works fine. However when configured for NTFS, there is nothing listed under /udisk folder. Is there is anything else I am missing? Satish
look for /dev/sda1..../dev/sdb1 or so. /udisk is a strange hack from the automounter. The automounter mounts only FAT to /udisk, it ignores ext2 too. Maybe you have to mount it by hand or provide your own mount script in /etc/mdev.
Hello Satish, can you tell us the transfer rated from and to the usb disk? Thanks Pete
Unfortunately we are not measuring transfer rate and we are just loading the USB disk at the moment. If you can explain me how to measure, I can experiment for you and let you know within reasonable time. Satish8789
Dear skip2816 Thanks a lot for your help. However I am facing a new problem. The NTFS USB Disk is opening in read only mode. Do you have any clue on why this could be happening and what could be solution? Thanks Satish Message on terminal: NTFS-fs error (device sda1): load_system_files(): Volume is dirty. Mounting read-only.
hi all, i have plugged a pen drive in mini2440 but am not able to copy a simple text or exe file on the board. Please help! i only need to run a compiled file from my pc on the board. Thanks in advance. :)
