Dear all, Do you know if u-boot is able to manage SDHC MMC cards? I use u-boot 1.3.2 for mini2440 128Mb, and when trying to initialize the card, I get this error message : MINI2440 # mmcinit trying to detect SD Card... ===============> MMC CMD Timeout MMC found. Card desciption is: Manufacturer ID = 000000 HW/FW Revision = 0 0 Product Name = Serial Number = 80ff00 Month = 0 Year = 1997 ===============> MMC CMD Timeout ===============> MMC CMD Timeout READ_BL_LEN=0, C_SIZE_MULT=0, C_SIZE=1020 size = 0 ===============> MMC CMD Timeout ===============> MMC CMD Timeout ===============> MMC CMD Timeout mmc_block_read: err SDIDSTA=0x00000020 MINI2440 # Any ideas? Thanks
U-boot and SDHC
As far my experience my u-boot always worked fine with MMC. The kinda msg u got i got once when the card wasnt in the socket..check if ur socket is loose or somethin'.. mmcinit and mmc try both... may be!!
Thanks for your advice. But unfortunately, I have already done this test and the socket is Ok, it works with Qt and WinCE. I thought it could be something like a wrong MMC type : SD cards (<= 2Gb) do not have the same addressing as SDHC (> 2Gb) cards as far as I know. And I thought maybe u-boot supports SD cards but not SDHC ones. But I've read that some people managed to make u-boot work with 32Gb cards. So I don't know where is my problem...
MINI2440 # mmcinit trying to detect SD Card... ===============> MMC CMD Timeout MMC found. Card desciption is: Manufacturer ID = 000000 HW/FW Revision = 0 0 Product Name = Serial Number = 80ff00 Month = 0 Year = 1997 ===============> MMC CMD Timeout ===============> MMC CMD Timeout READ_BL_LEN=0, C_SIZE_MULT=0, C_SIZE=1020 size = 0 ===============> MMC CMD Timeout ===============> MMC CMD Timeout ===============> MMC CMD Timeout mmc_block_read: err SDIDSTA=0x00000020 MINI2440 # please give the solution for this; Thanks
MINI2440 # mmcinit trying to detect SD Card... ===============> MMC CMD Timeout MMC found. Card desciption is: Manufacturer ID = 000000 HW/FW Revision = 0 0 Product Name = Serial Number = 80ff00 Month = 0 Year = 1997 ===============> MMC CMD Timeout ===============> MMC CMD Timeout READ_BL_LEN=0, C_SIZE_MULT=0, C_SIZE=1020 size = 0 ===============> MMC CMD Timeout ===============> MMC CMD Timeout ===============> MMC CMD Timeout mmc_block_read: err SDIDSTA=0x00000020 MINI2440 # please help me with this
yes, I have downloaded it from download section which is u-boot256.bin.and I have mini2440 1GB NAND flash.
I had the same problem, but I don't remember how I solved it. I have a 128Mb version, so maybe I used Buserror's version. Maybe you can merge his SDHC patch in the version you use? In my case, I have chosen to use a NFS server instead: it saves SD card connector from damages
