Hi I am using Mini2440 and I want to share some files and folders in my WinCE5.0 device over my local area network.. I can access other computers on the network and browse their shared folders on my wince device but I can't access my WinCE device folders on other computers.. I am using usb wifi stick on my device.. Can someone please tell how can I be able to share files and folders in WinCE device Is there any changes I have to do in the image or any registry settings..?? Thanks in Advance Regards Hussain Aftab
how to share folders in WINCE..?
Hi, The mini2440 sould have a web page where you set up shares and permissions. Use a web browser and browse to your mini2440. Thank you, Errol
Thanks for your reply.. but i don't understand what are you trying to say..!! since i am using WinCE5.0 it has a web browser,where i can browse internet I have also configured a web server in my wince device i can access it on my network.. but the problem is when i try to access my wince device from other computer it doesn't show any thing... i mean i have assigned the IP: 192.168.1.86 to my WinCE device, when i type "\\192.168.1.86" on RUN it doesn't show anything, but it do show me the web page when i type "http://192.168.1.86" on internet explorer because of web server.. but i Want to view web server as well as i want to share folders in the same way as i do in my desktop computer...
I don't remember very well, I tested this thing a long time ago on another platform than mini2440. Try to add following components : - File Server (SMB/CIFS) - File server customizable UI After sygen/flash, you should be able to access SMB server configuration at the following address : http:\\ip address of you board\remoteadmin In this webpage, you will have to enter a name for your device and a administrator password. Then, in the control panel, add a network card by selecting the network adapter, click on "submit query", and you would be able to share folders... If it doesn't work, I will try to find some time in the coming nights to test it by myself on the mini2440 before to write a tutorial on my website. domdom
Ok, so you must go to http://192.168.1.86/remoteadmin There you must configure sharing. WinCE doesn't know what you want to share. At http://192.168.1.86/remoteadmin you must configure it. Thank you, Errol
I wrote a little article to show how to share a Windows CE folder : http://www.domodom.fr/spip/Sharing-folders-with-Windows-CE-6.html?lang=en domdom
Thanks for your info domdom... I am successfully share wince 5.0 folder on my pc. but i want to share wince 5.0 folder in my another wince 5.0 board. I try to access to http://ip/rmoteadmin in second wince 5.0 board but it given bellow error. ' The page can't desplayed..." in address bar changed to below text. res://\Windows\Shdoclc.dll/dnserror.htm Please give the answer ASAP. Actually my requirement is i want to use same dbfile for both machines (micro2440 with wince 5.0) through network sharing.
