Hello, I have a mini 2440 board with nec 3.5" lcd display. There is a problem with the lcd. Screen starts from approximately 7-10 pixel to the left side. I mean, there is a blank column on the screen with 7-10 pixel width. What is the problem here? How can I solve this problem, can you please help me? Thanks in advance, Kindly Regards
N35 LCD Problem
I had this problem two days ago. This happened me because the linux image has some bugs. Try another linux image.
It doesn't have some bugs. There are 2 3.5" screens on the mini2440, the old one is the T35, the new one is made by NEC and it is the N35. If you're getting the shifted effect you're using the wrong image. In this case you need the T35. Cheers
I had the same problem. even tried reflashing the image with a newer version of the N35 image with the same effect before looking at the screen part number. Turns out the seller I purchased from on Ebay was listing the auctions as "NEC 3.5 + ARM9 Development board" and I assumed it to be correct. once I found that their was multiple suppliers involved It was obvious :) Nothing wrong with the board or LCD so far just listed wrong, honest mistake.
It would appear that I have the same issue. I ran the test file via download called 2440test_A70.bin. I found this forum thread and tried the file called 2440test_N35.bin and it was showing as shifted. I then tried 2440test_T35.bin and the image displays correctly. When I boot the device to the linux image I get a corrupted display. It is very bright and stripped with white and some other colour. Can I assume that when I get the linux image built with the correct driver and downloaded onto the device that this will display properly? Cheers!!
