Hello all, Because I get errors flashing the WinCE6 NK.bin I want to update my NOR bootloader to the latest version. I have installed H-Jtag When I attach my device to the parallel port using the cable that was in the package H-tjag does recognize any device automatigically. When I switch to custom settings as described in the manual found on this site It stil says: no devices detected... When I test my LPT port I says that it works properly.. What do I do wrong? I set the switch to NOR flash have the JTag attached and then power on the board... Suggestions anyone?? Thanks in advance!
h-Jtag does not find device
Correction to original messsage: When I attach my device to the parallel port using the cable that was in the package H-tjag does NOT recognize any device automatigically.
