hello everyone, i have a board of s3c2440a arm, the new one of friendly arm. i also have jtag module which connects pc with parallel port. i m using 1:1 parallel port cable and the jtag is connected to board with frc cable i m using ADS1.2 for arm programming which is givne in cd. and in that i have written the code of led flashing. it gets compiled very well. and when i select debug, it gets connected to ADX debugger. but i m unable to connect to target even if i use 'config target' option and under that i select serial/parallel port configuration. and switch is on NAND bootloader. and 'flash download' under 'file menu' is also disabled. i tried using NOR bootloader but it is of no use. window of AXD debuuger is closed automatically. i have gone through the pdf of axd debugger, in that it is mentioned that we require to configure the 'multi-ice server' software for jtag download. i m unable to find it in cd provided by vendor nor it is available free on net. can you tell me where can i get this software from? i configured the target for serial port only and then it got connected but still m not able to download the program into it. i used DNW software and usb driver for arm is installed but it gives message of no connectivity. i tried H-JTAG but still the result is same. pls help me thank you all regards kpppp
