I am using mini2440 with 128 mb nand.In this I done Linux installation
through the
1)--> u-boot-128.bin,
2)--> linux kernel
3)--> GPE.
But,After installation I on the board.Just display came like below
" INDUSRIAL ARMWORKS "
and after some time system not getting on.
/*************************** GETTING ERROR *****************************/
U-Boot 1.3.2NAND: Bad block table not found for chip 0
128 MiB
USB: S3C2410 USB Deviced
In: serial
Out: serial
Err: serial
MAC: 08:08:11:18:12:27
Loading from NAND 128MiB 3,3V 8-bit, offset 0x60000
Image Name: Linux-2.6.29.4
Created: 2009-05-20 11:45:59 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 1945740 Bytes = 1.9 MB
Load Address: 30008000
Entry Point: 30008000
## Booting kernel from Legacy Image at 32000000 ...
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing
done, bootin.
Linux version 2.6.29.4 (fuchs@case) (gcc version 4.1.2) #21 Wed May 20
13:45:47 CEST 2009
CPU: VIVT data cache, VIVT instruction cache
Machine: MINI2440
CPU S3C2440A (id 0x32440001)
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
Kernel command line: root=/dev/mtdblock3 rootfstype=jffs2
console=ttySAC0,115200
irq: clearing pending status 02000000
PID hash table entries: 256 (order: 8, 1024 bytes)
console [ttySAC0] enabled
Memory: 64MB = 64MB total
Memory: 60748KB available (3596K code, 398K data, 132K init)
SLUB: Genslabs=12, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
net_namespace: 672 bytes
MINI2440: Option string mini2440=0tb
MINI2440: LCD [0:240x320] 1:800x480 2:1024x768
S3C2440: IRQ Support
S3C24XX DMA Driver, (c) 2003-2004,2006 Simtec Electronics
DMA channel 0 at c4808000, irq 33
DMA channel 1 at c4808040, irq 34
DMA channel 2 at c4808080, irq 35
DMA channel 3 at c48080c0, irq 36
bio: create slab <bio-0> at 0
TCP reno registered
JFFS2 version 2.2. (NAND) �© 2001-2006 Red Hat, Inc.
msgmni has been set to 118
alg: No test for stdrng (krng)
io scheduler noop registered
io scheduler anticipatory registered (default)
io scheduler deadline registered
io scheduler cfq registered
Console: switching to colour frame buffer device 60x53
s3c2440-uart.0: ttySAC0 at MMIO 0x50000000 (irq = 70) is a S3C2440
s3c2440-uart.1: ttySAC1 at MMIO 0x50004000 (irq = 73) is a S3C2440
s3c2440-uart.2: ttySAC2 at MMIO 0x50008000 (irq = 76) is a S3C2440
loop: module loaded
dm9000 Ethernet Driver, V1.31
eth0 (dm9000): not using net_device_ops yet
eth0: dm9000e at c486a300,c486e304 IRQ 51 MAC: 08:08:11:18:12:27 (chip)
s3c2440-nand s3c2440-nand: Tacls=1, 9ns Twrph0=3 29ns, Twrph1=2 19ns
NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V
8-bit)
Creating 4 MTD partitions on "NAND 128MiB 3,3V 8-bit":
0x000000000000-0x000000040000 : "u-boot"
0x000000040000-0x000000060000 : "u-boot-env"
uncorrectable error : <5>0x000000060000-0x000000560000 : "kernel"
uncorrectable error : <5>0x000000560000-0x000008000000 : "root"
uncorrectable error : <6>ohci_hcd: USB 1.1 'Open' Host Controller (OHCI)
Driver
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
usbcore: registered new interface driver libusual
s3c2440-usbgadget s3c2440-usbgadget: S3C2440: increasing FIFO to 128 bytes
mice: PS/2 mouse device common for all mice
input: gpio-keys as /devices/platform/gpio-keys/input/input0
s3c2440-ts s3c2440-ts: Starting
Created group ts filter len 12 depth 2 close 10 thresh 6
Created Median ts filter len 20 depth 2 dec 24
Created Mean ts filter len 4 depth 2 thresh 65535
Created Linear ts filter depth 2
s3c2440-ts s3c2440-ts: 4 filter(s) initialized
s3c2440-ts s3c2440-ts: successfully loaded
input: s3c2410 TouchScreen as /devices/virtual/input/input1
S3C24XX RTC, (c) 2004,2006 Simtec Electronics
s3c2410-rtc s3c2410-rtc: rtc disabled, re-enabling
s3c2410-rtc s3c2410-rtc: rtc core: registered s3c as rtc0
i2c /dev entries driver
s3c2440-i2c s3c2440-i2c: slave address 0x10
s3c2440-i2c s3c2440-i2c: bus frequency set to 395 KHz
at24 0-0050: 1024 byte 24c08 EEPROM (writable)
s3c2440-i2c s3c2440-i2c: i2c-0: S3C I2C adapter
S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics
s3c2410-wdt s3c2410-wdt: watchdog inactive, reset disabled, irq enabled
cpuidle: using governor ladder
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
mapped channel 0 to 0
s3c2440-sdi s3c2440-sdi: powered down.
s3c2440-sdi s3c2440-sdi: initialisation done.
s3c2440-sdi s3c2440-sdi: running at 0kHz (requested: 0kHz).
s3c2440-sdi s3c2440-sdi: running at 198kHz (requested: 197kHz).
Registered led device: led1
Registered led device: led2
Registered led device: led3
Registered led device: led4
usbcore: registered new interface driver hiddev
usbcore: registered new interface driver usbhid
usbhid: v2.6:USB HID core driver
Advanced Linux Sound Architecture Driver Version 1.0.18a.
No device for DAI UDA134X
No device for DAI s3c24xx-i2s
S3C24XX_UDA134X SoC Audio driver
UDA134X SoC Audio Codec
asoc: UDA134X <-> s3c24xx-i2s mapping ok
s3c2440-sdi s3c2440-sdi: running at 16875kHz (requested: 25000kHz).
mmc0: new SD card at address 8d54
mmcblk0: mmc0:8d54 SU02G 1.89 GiB
mmcblk0: p1
ALSA device list:
#0: S3C24XX_UDA134X (UDA134X)
TCP cubic registered
s3c2410-rtc s3c2410-rtc: setting system clock to 2010-03-11 17:30:59 UTC
(1268328659)
Empty flash at 0x00003ffc ends at 0x00004000
Empty flash at 0x00007ffc ends at 0x00008000
Empty flash at 0x0000bffc ends at 0x0000c000
Empty flash at 0x0000fffc ends at 0x00010000
Empty flash at 0x00013ffc ends at 0x00014000
Empty flash at 0x00017f64 ends at 0x00017fa4
jffs2_scan_eraseblock(): Magic bitmask 0x1985 not found at 0x00017fa4:
0xffff instead
Empty flash at 0x00017fa8 ends at 0x00018000
Empty flash at 0x0001bffc ends at 0x0001c000
Empty flash at 0x00023ffc ends at 0x00024000
uncorrectable error : <4>mtd->read(0x18054 bytes from 0x27fac) returned ECC
error
Empty flash at 0x00027fa8 ends at 0x00028000
Empty flash at 0x0002bffc ends at 0x0002c000
Empty flash at 0x0002fffc ends at 0x00030000
uncorrectable error : <4>mtd->read(0xc04c bytes from 0x33fb4) returned ECC
error
Empty flash at 0x00033fb0 ends at 0x00034000
Empty flash at 0x00037ffc ends at 0x00038000
Empty flash at 0x0003bffc ends at 0x0003c000
Empty flash at 0x00043ffc ends at 0x00044000
Empty flash at 0x00047ffc ends at 0x00048000
Empty flash at 0x0004bffc ends at 0x0004c000
Empty flash at 0x0004fffc ends at 0x00050000
Empty flash at 0x00053ffc ends at 0x00054000
Empty flash at 0x00057ffc ends at 0x00058000
Empty flash at 0x0005bffc ends at 0x0005c000
CTRL-A Z for help |115200 8N1 | NOR | Minicom 2.3 | VT102 |
Offline
Empty flash at 0x020a7ffc ends at 0x020a8000
Empty flash at 0x020abffc ends at 0x020ac000
Empty flash at 0x020afffc ends at 0x020b0000
Empty flash at 0x020b3ffc ends at 0x020b4000
Empty ...stripped-down
boot of nand-128MB problem
uncorrectable error : <5>0x000000060000-0x000000560000 : "kernel" uncorrectable error : <5>0x000000560000-0x000008000000 : "root" looks suspect. Go to: https://www.blogger.com/comment.g?blogID=11320970&postID=41189769619... and make sure you are following their suggestions.
hello,
I get the same error too. I am trying to install linux u-boot + linux +
rootfs(jffs2) on mini2440(128Mb version). I get the same error as above.
Can anyone please site why this problem occurs and steps to overcome it.
By the way, I looked at the above link and found no relevant solution.
Thank you.
Maybe you need to define the correct offsets and sizes of the partitions in mach-mini2440.c before compilation. See http://mayer.spaces.eepw.com.cn/articles/article/item/59592 (maybe different for your source).
