Running “Hello, World”
MMS 2010-03-09 08:49:54 Link
im trying to run "Hello, World"
on Qtopia FrameBuffer
but i have error
"line 17 :hello is not a command "
from run script file
<code>
14 export QPEDIR=$PWD
15 export KDEDIR=$PWD/../kde
16 sleep 3
17 hello –qws
</code>
plz help
skip2816 2010-03-09 10:51:56 Link
you can try:
- do normal start up with qtopia
- open qtopia's console
- start your app (without any extra parameters like -qws)
Its should run, but without things managed by qtopia (i.e. entry in the
status bar, frame decorations). And you be able to see log messages.
skip
andromeda 2010-03-09 14:57:40 Link
try chmod +x hello
./hello -qws in console mode
Rascol 2010-07-10 14:12:39 Link
Hi
Edit run-hello script , change ./hello -qws with
/opt/FriendlyARM/mini2440/x86-qtopia/qtopia-2.2.0-FriendlyARM/qtopia/bin/hello
-qws
and then try again , it will work.
ragip.
Reply
Name
eMail (not visible)
Text
Please enter the number 1245
