Hi, Retail builds go just fine, but when I try to make debug builds, get stumped with errors like: NMAKE : U1073: don't know how to make 'D:\ce5\platform\smdk2440\lib\ARMV4I\debug\cardserv.lib' BUILD: [01:0000000846:ERRORE] NMAKE.EXE -i -c BUILDMSG=Stop. NOLINK=1 NOPASS0=1 failed - rc = 2 BUILD: [00:0000000847:PROGC ] Files Warnings Errors Any pointers to generate debug builds?
Cannot make debug builds with ce 5.0 BSP.
Hi, I had problems with debug builds too. Not that problem though. Is the card bus diabled in mini2440.bat? BTW, i have found no use in trying to build a debug build. With KITL not available it doesn't help. Please correct me if i'm wrong, i'm new to CE debuging. Also, i had problems with CE5 and CE6 with fitting a debug build into 32MB. I also found that some debug exports where missing from most of the custom drivers. I just copied them in from the PCI driver i think. If you need more info then i can provide when i get home. In the end i gave up on real debugging functionality and settled for debug printing messages over serial. Thank you, Errol
