Hi, I'm playing with ext3 on an SD card inserted in the SD slot and running into problems. The messages looks like this: mmcblk0: error -110 transferring data, sector 2055079, nr 104, card status 0x900 and the same with error code -84. As I can see from the kernel sources, these values correspond to time outs and illegal byte sequences. The content of the messages varies from time to time. Sometimes the problems appeared just after boot up, and sometimes there pass a lot of time of normal operation before I get them. Is there a known solution for the problem?
Inrernal SD Slot
Most likely a long-shot, but can you try different SD cards? I know from some work I have done with SD cards that they can vary, especially on initialisation sequences and operation speed while initialising. Think things change quite a bit at the 4GB level. Good luck!
I want to, but right now I only have two identical Kingston SD 2G. Both cause the same messages. An both work well under Ubuntu Hardy and with my camera. Will I decide to get a new SD (or SDHC) card to try, what is the vendor/model that most likely will work smoothly with the board? I tried to change the time out limits in the kernel. This helps for some time, but then the messages appear again.
Go to www.avrfreaks.net and forums and search for Kingston. Here's one http://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&... Somewhere in there in a list of cards and their responses to initialisation. Specifically 2GB Kingston SD cards.
Just tried a full-size SDHC Transcend 4Gb. With no success -- the same error appears as long as the card is inserted to the internal SD slot. Given the same card is in a USB reader inserted to the USB port, everything is okay then. Could anybody confirm the SD slot works fine with at least some sort of cards? Thanks.
I can confirm that using the standard factory install of Qtopia and Linux 2.6.29 that a 2Gb Alldata card works.
Thank you, Dave. Can you also tell me if you tried a pre-compiled or a locally compiled kernel? If first, could you please try a locally compiled 2.6.29? Thanks again.
