Which pin of GPIOs are for LEDs ?
aruangra 2010-03-04 05:47:04 Link
Hello
I want to use the GPIO to trigger a relay board. To skip the complexity of
compiling the kernel and dealing with the GPIO driver, I want to use the
GPIO for LED and use the available LED program. The manual mentions that
the LEDs are linked to GPB5 - GPB8. However, GPB5 - GPB8 are not written in
the description of the GPIO connector pins.
Does anyone know which pin of the GPIO connector are for LEDs?
I need only one channel to trigger the relay. Is there any other simple
solution?
Thank you.
Best regards,
Anat
Mathias Tantau 2010-03-10 19:31:55 Link
hello aruangra,
which operation system do you use?
Reply
Name
eMail (not visible)
Text
Please enter the number 9170
