Hi, I'm trying to get the Debian Lenny distro working on the mini2440 board. At this moment everything is fine and I have Lenny bootable and woking well. The only issue is the Ethernet which doesn't seem to be working. I used the following sources: http://www.friendlyarm.net/dl.php?file=linux-2.6.29-mini2440_20090708.tgz and the default config for the 7" display with a single changed line to support ext2. Plus, I fixed the SD driver about timings in order to make it working smoothly with my card (to which the root file system is installed). So, the question is: should the eth0 (DM9000) port be working out of the box for the default config or should I enable more options to get it working?
Kernel config again
The config does enable Ethernet networking by default. The only thing to do to make this working is specifying "ip=dhcp" in the Linux command line.
