Hi, I am new to QT embedded. I have prepared an application in QT SDK 4.6.1. on x86 platform based linux. Now i wish to put that application on ARM9 board device friendly arm with linux 2.6.13 installed. What steps should i follow so that i can run my application on friendly arm?? QT documentation says some procedure which i did not understand. Do i need any other compiler to compile QT project which will create the executable for ARM9 board?
Cross-compiling QT application
I think this thread might help you out: http://www.friendlyarm.net/forum/topic/439?lang=en Also I'd suggest to look into Openembedded ( http://wiki.openembedded.net/index.php/Getting_started ) or maybe Buildroot.. Look around, there are tutorials on how to do this. Good luck! ;)
Hi, I do develop Qt applications on the mini2440 and it works great. - You have to setup the ARM compiler on your host machine so you can build your Qt application for the ARM9 target. - After, you have to compile the Qt library with this ARM compiler. This version of the library will have a specific ARM configuration so when you call QMAKE, it will know which compiler to invoke and which plugins to enable. -Then once all of this is done (this took me looong time !) you have to setup the mini2440 to run Qt apps. There are some good walkthrough to execute all of the above. http://blog.cor-net.org/embedded/mini2440/qt-45-on-mini2440/ http://automon.donaloconnor.net/date/2009/01/25/ http://emsys.denayer.wenk.be/emdem/course/qt.pdf Have fun !
