Hi How can I move cursor mouse in (x, y) position ? It's possible to move cursor under C language ? Thanks a lot !
Move Cursor Mouse
You wont get any answer this way! What are you exactly trying? To move the cursor in a graphical user interface like qtopia or in the terminal? If you are talking about the terminal you will have to use something like ncruses to move the cursor.
Hi Philipp Karbach, The main purpose is to move cursor using eye movement. Yes, I want to do this in a graphical user interface because the GUI will be displayed on LCD monitor through VGA converter board. My image processing application compute many operations in a limited time, so the cursor movement will be processed fast. The time is critical. The GUI will be divided in some areas and it will be look like a menu and the user should be choose something using cursor movement. This it's not so possible using terminal because I must choose something. Thanks a lot and I wish you a nice day.
Thanks Philipp Karbach, I just have installed the ncurses library on my laptop target and it seems to work great. I can move a character instead of arrow cursor but I must think about of my areas. Any advices are good. Thanks again
If this is a graphical issue than you could just receive your cursor value (by transposing the coordinates etc. or get the mouse position) and draw a little block or circle where you need it. It shouldnt be hard to do that. I'd do it directly in the framebuffer. You already have the camera example code there...
