hi i build windows ce6 nk.bin file and jtag flash whit new version of supervivi every thing is ok , and windows ce6 is running after instal, but when i reset mini2440 board OS can't start and display is white i have that proplem whit ce5 , befor jtag my board windows ce5 work as well , but now i have serious problem when i type X in supervivi menu [x] bon part 0 320k 2368k result is very bad ! :( 3BEC000: is bad 3BF0000: is bad 3BF4000: is bad 3BF8000: is bad 3BFC000: is bad 3C00000: is bad 3C04000: is bad . . i don't understand what is mean please help me
windows can't boot after installing
Try files from www.arm9.net, becouse files from friendlyarm.net coused at my device the same - WinCE didn't want to start. Files from arm9.net work fine.
Thank's Adamczesku for your answer my ce5 work fine befor i jtag mini2440 , but after jtag my board it can't boot :( i try with arm9 ce image but my problem not solved when i type x in supervivi menu all block is bad .it possible nand flash is damaged?
http://www.friendlyarm.net/forum/topic/630?lang=en The search engine has been up-graded on this site.
