Hi, I successfully downloaded the arm-linux-gcc-4.3.1 however, I couldn't find the /root/bashrc to edit the file as instructed in the andahammer.com documentation. I'm using my Centos 5.0. Please advise. Thanks, puma
/root/bashrc couldn't find
If Centos 5 is similar to desktop Kubuntu then in your .profile file, using an editor add: export PATH =$PATH:/../../usr/local/arm/4.3.1/bin the extra double dots being your path to arm-linux-gcc-4.3.1 Did you mean 4.3.2?
