I have a problem and am in need of some suggestions on how to debug. I'm reviving an old ARM project and want to switch to buildroot because I think it will help me keep things up to date going forward. I have gone through the buildroot configuration process, built the toolchain (binutils 2.19.1, gcc-4.3.4 uClibc-0.9.30.1). As long as I compile with shared libraries I can run them on my old system (2.6.13 kernel, some old version of uClibc). Statically linked files fail with an illegal instruction on the old system. I have built a new version using 2.6.23 using buildroot to do it for me. I can load this kernel using tftp from uboot and it initializes itself and mounts the root filesystem from my server (I watched the mount request and the kernel reports a successful mount of the root filesystem). When it tries to exec init (a link to busybox) it just hangs. At this point I can ping the system and characters typed on the serial console are echoed. It isn't completely dead. I tried replacing /sbin/init with an executable that creates a file in the root filesystem as well as print output to the console. Neither happen. I can see the root filesystem from my server and no file is created. I suspect a library incompatibility issue. The illegal instruction seems to be a big hint. I configured the buildroot with generic_arm. Any help or suggestions of how to instrument this to help track down the problem would be greatly appreciated. Thanks, Ed
