I'm still trying to install Windows CE. From the manual I see the procedure requires the file eboot.nb0 to download the .bin image. From what I see when typing "w" in supervivi I also see it tries to read eboot partition before downloading. Unfortunately, I can't find the file on my disk, nor there is such a file among Windows CE's images I have. Could anybody please give a link or upload the file? Or should I use the nboot.bin file instead? Thank you.
eboot.nb0
It works with the following sequence from menu select "n" transmit the nboot_N35.bin file with DNW from menu select "i" transmit the NK_N35.nb0 file with DNW wait for all reporting to finish (it takes some time) Then select from menu select 'b' Wait for some minutes for the system to boot. The build image is in chinese , and the touchscreen aligment is mirrored. Regards.
