Dear all, I'm facing some problems with windows CE 6.0. First of all, I have to say that I'm a beginner so I don't know anything in WinCE and mini2440. I have a 128Mb board, and I would like to add some components to the image to make tests. When I add too many components, I get this error: "Ram Start Overlaps ROM Binary". In WinCE 5.0, I just had to modify the config.bib file and it worked. Now in WinCE 6.0, I would like to be sure the image is designed for 128Mb and not only 64 or less in order to have enough space to add components. I have read on some topics the mapping was made in oemAddressTable but I'm not able to locate it. As far as I have understood, config.bib file only contains virtual address space, and oemAddressTable makes the translation between physical and virtual addresses. Another problem I have, when I try to load an image I have generated myself in the board, transmission stops a few bytes before the end. I have flashed version 2.0 of superVivi in NOR flash and use last version of DNW. I have not this issue with the WinCE 6.0 image provided on the CD image. Do you know if there is some kind of maximum image size for the NK.bin image? Thanks
Windows CE 6.0 image generation
Hi, I downloaded wince6.0 BSP, is there a procedure out to build it with wince 6.0 on mini2440? thanks for the help, -Sab
