Hello All I compiled linux kernel for mini2440(linux-2.6.29-mini2440-20090708.tgz) When i am executing with my bootloader Uncompressing Linux....................................................... ........................................................................... done , booting the kernel. Then it stops. But when i am using supervivi,it isworking fine. I send machine type as 1999 when i seach for machine_type.h in linux-2.6.29-mini2440-20090708\linux-2.6.29\include\asm-arm but i did not found. Is there any other boot parametes are required . Please suggest me,to correct the mistake
Booting problem
If you use Supervivi to bootload your kernel and rootfs images everything works OK. Then when you use ? to bootload your kernel and rootfs images it stops. You have to tell us what this other bootloader is and you need to tell us what kernel and rootfs images you are trying to download. What format is your kernel image in (zImage or uImage or ?) What format is your rootfs in (YAFFS or JFFS2 or ?)
