Hello devef, I have issue working with framebuffer do you any example programs. Regards, sam
framebuffer
Take a look at ezfb, its very nice :) I've made a simple winamp-clone for linux-framebuffer on a mini2440 with ezfb.
can you send some links for same.actually I want to write character using framebuffer on GLCD do u know how this can be done????????
Hi Can somebody explain how it's framebuffer used for draw anything ? Some like a simple dot. I think it's very useful for everyone to know how can be frambuffer accessed. Thx
You can do
cat /dev/urandom > /dev/fb0
and you'll see the screen being filled by an amount of colors. And you can
also try to write your own text and see what's happening, like
echo "some text" > /dev/fb0
Even you can try to create an application that writes decimals instead of
characters.
Sérgio
Sérgio, Thanks for that! Could you suggest the steps required to get USB keyboard input directed to the frame buffer? Cheers, Dave
Hi, The JPGs and BMPs have 3 bytes (RGB) in their data. When I copy data from the framebuffer, it fetches me 2 bytes for every pixel. I want to know how these 3 bytes are mapped into two bytes in framebuffer. I am using framebuffer in Busybox+Qtopia 2.2.0 on Micro2440+T35. TIA Vikas
@TheSergon13 I tried to write some text directly into framebuffer using this command " echo "abcd" > /dev/fb0 " but nothing is happen. Why ? @davef For you it works ? Regards, Irinel
Vikas, See below to find answer for your Display: // 5:6:5 16bit format rgb0 = (((U16)r0>>3)<<11) | (((U16)g0>>2)<<5) | (((U16)b0>>3)<<0); //RGB565. rgb1 = (((U16)r1>>3)<<11) | (((U16)g1>>2)<<5) | (((U16)b1>>3)<<0); //RGB565. rgb = (rgb1<<16) | rgb0; r0,g0,b0 is first pixel and r1,g1,b1 is for second pixel. so thus two pixels are used to show 6 bytes of rgb data in mini2440. Regards, Kailas
I uploaded a sample source code to draw two lines at y=100 and y=101. For me doesn't work to set red and green color for lines.
I was able to Images on VGA but if character need to be displayed then how to do it?? since everything we write into framebuffer is pixel( I mean framebuffer workes only for graphical mode how to switch to text mode)
vikas, I should write your functions that display a character or you can try a library like ezfb, MiniGUI, etc.
Hi azzido, I've compiled your code successfully but when I ran it on the device it gives "Segmentation Fault" do you have any ideas about that ?
Hi Vikas Can you explain here how did you display the images on VGA by writing into the framebuffer as I am also trying to do the same. I want to display images captured by a USB camera. Regards Tan
