Hi , If someone has successfully managed to boot the linux kernel via u-boot for the 128Mb board could please upload the output of printenv and mtdparts regards --fatbrain
u-boot 128Mb boards
Hi, I managed to install u-boot for 128Mb board with kernel 2.6.32 (http://blog.leshak.ru/english/pages/how-to-install-debian-50-lenny-to-ar... and http://code.google.com/p/mini2440/wiki/Emdebian) MINI2440 # printenv bootdelay=3 baudrate=115200 ethaddr=08:08:11:18:12:27 ipaddr=10.0.0.111 serverip=10.0.0.4 netmask=255.255.255.0 usbtty=cdc_acm mtdparts=mtdparts=mini2440-nand:256k@0(u-boot),128k(env),5m(kernel),-(root) mini2440=mini2440=0tb bootargs_base=console=ttySAC0,115200 noinitrd bootargs_init=init=/sbin/init root_nand=root=/dev/mtdblock3 rootfstype=jffs2 root_mmc=root=/dev/mmcblk0p2 rootdelay=2 root_nfs=/mnt/nfs set_root_nfs=setenv root_nfs root=/dev/nfs rw nfsroot=${serverip}:${root_nfs} ifconfig_static=run setenv ifconfig ip=${ipaddr}:${serverip}::${netmask}:mini2440:eth0 ifconfig_dhcp=run setenv ifconfig ip=dhcp ifconfig=ip=dhcp set_bootargs_mmc=setenv bootargs ${bootargs_base} ${bootargs_init} ${mini2440} ${root_mmc} set_bootargs_nand=setenv bootargs ${bootargs_base} ${bootargs_init} ${mini2440} ${root_nand} set_bootargs_nfs=run set_root_nfs; setenv bootargs ${bootargs_base} ${bootargs_init} ${mini2440} ${root_nfs} ${ifconfig} mtdids=nand0=mini2440-nand filesize=1F86FC bootargs=console=ttySAC0,115200 noinitrd init=/sbin/init mini2440=1tb ip=dhcp root=/dev/mmcblk0p2 rw noinitrd root=/dev/mmcblk0p2 rw ip=dhcp bootcmd=nboot.e kernel ; bootm partition=nand0,0 mtddevnum=0 mtddevname=u-boot Environment size: 1199/131068 bytes MINI2440 # mtdparts device nand0 <mini2440-nand>, # parts = 4 #: name size offset mask_flags 0: u-boot 0x00040000 0x00000000 0 1: env 0x00020000 0x00040000 0 2: kernel 0x00500000 0x00060000 0 3: root 0x07aa0000 0x00560000 0 active partition: nand0,0 - (u-boot) 0x00040000 @ 0x00000000 defaults: mtdids : nand0=mini2440-nand mtdparts: <NULL>
