Hello again. I'm trying to backup the NAND flash. After the BIOS menu appeared I connect the USB cord and press "u" to start the back up procedure. The the manual says there should be the "Backup NandFlash to File" menu item I should use for uploading the content. However, my copy of the DNW tool only has the "Transmit", "Rx Test" and "Status" items under the "USB Port" menu. The version of the tool, as appeared on the title of the window, seem to be the same (0.50A), but it looks like I use a different version. Can anyone please clarify this? Thanks.
DNW tool
Thank you much, that worked. I also looked at the newest supervivi_20090721.zip in the download section and found it contains two images of large sizes. When trying to load any of them my board says the image is too large. Can you explain what the images are for?
OK, thank you. But about the supervivi images? When I try to install them, the board says: Supervivi> load flash vivi u USB host is connected. Waiting a download. Length of file is too big : 256348 > 163840 Failed downloading file Should I re-partition the NAND flash or something?
There are different version of DNW floating around. My version says Transmit/Restore and Backup NAND Flash to file under USB Port. There are versions that just say Transmit. In learning to use DNW I came to the "perception" that you had to start at the beginning and work through all the steps. I seemed to be able to skip the first step <x> (partition flash) but not the second step <v>. Try doing it from the beginning. Also, I had to change the start address to 0x32000000 to get Qtopia to work properly, but that doesn't sound like your problem. Good luck!
Umm, I tried to start with the "x" command, just as it stated in the manuals, but it fails with the images. Do you mean your board allows to download the big (those are about 256K) images with no special configuring, just out of box?
you need to have bigger supervivi in the NORflash in order to be able to program (from supervivis menu anyway) the 256K Vivi image (or program form commandline version of supervivi tellinf some size larger than 260k) I use HJTAG version 0.9.1 to program the NORflash and after some trouble with badblock I succeeded getting the system working. P.S: if your board has 64M NAND, dont bother programming the supervivi-128M it would not work too well.
Eero, thanks a lot for the point. Can anybody tell the start addresses of the supervivi in NAND flash and/or RAM so I can load it manually?
To those who can to download the large vivi images: can you please write out what your supervivi says when you type supervivi> part show Thank you.
blankvin: There is a linux tool that allows you to upload files to the Mini2440 through USB. You have to use your a serial program like picocom or minicom or gtkterm to send commands to the Mini2440, and send files to it using the USB program. Here is the program, source and binary http://www.sendspace.com/file/aaor77
I just realized there was an error in the Makefile, so here is the fixed one. Make sure that when you compile that you have libusb-dev installed. To run the program, this is what I do: $ sudo usbpush supervivi_mini2440 http://www.sendspace.com/file/l77q5c
Dear all, I am trying to communicate with MINI2440 (128MB RAM), and trying to load images through DNW. help me to configure DNW for serial port configuration, system have COM16 (USB to Serial port), DNW having only COM1 to 4. And need DNW USB driver software. o have tried with DNW-0.6.0 OS is Windows-XP(SP2). Regards Babu.A
Thank you, Now i am able connect the target board via DNW. i am getting supervivi menu in terminal once only after resetting the board i am not getting the menu on terminal. and also not able to give commands to the target board. but the serial port is working manually i have checked out by putting jumper to 2 and 3 pins. regards Babu.A
