I've purchased the friendly arm board and it's been provided with Linux2.6.29 kerenl source. I want to compile this source and as per the procedure I tried to configure the kernel at the first step. For this which configuration file i should use? shall I use #make s3c2410_defconfig command and there is no s3c2440_defconfig file for this board. thanks Rajasekaran
Linux kernel configuration
download the kernel package from these site. Here are drivers included that you will not find in the original linux kernel. Also configuration files are added. There are any files named config_mini2440_xxx where the last letters stays for your screen model. Do export PATH=$PATH:/<path to your toolchain> cp config_mini2440_xxx .config make menuconfig make See http://friendlyarm.net/forum/topic/492?lang=en skip
