I built a sound player to test my micro 2440 sound system. It works fine on Ubuntu, I speak on mic and then listen recorded buffer on headphones... but on micro it doesn't work. I attached the c source code. Can anybody tells me if there's something wrong? Where can i find the "mp3 player" and "recorder" source code available on qtopia applications or any other source code that could help me? I have 2 other files (recorder.c and playfile.c). Using recorder.c i create a file with the buffer after reading /dev/dsp. With playfile.c i read the file created with recorder.c and i can heard everything, like a music player (using ubuntu). When I try to open the same file on micro2440, using the "same executable" (only difference is the cross compile for arm) i got the same sound, but much more faster and virtually incomprehensible. Seems that i have some problem with the play rate, but i don't have any idea of how to fix that. Anyone have a tip? Thanks in advance
problems with my sound player software
Hi Eduardo, its seams to the micro's sound has a problem with low sample rates. I encountered a similar problem. Try with sample rates 11025 or higher, its work (for my). For my application I need a sample rate of 8000. So I work with 16000 and throw away every second sample. See http://friendlyarm.net/forum/topic/397?lang=en (no response). But there is a difference, you use the sound chip on board, i use a sound chip connected via USB. skip
