This is Santosh working as Embedded Application Engineer,bangalore
I got a new board last week.
1. I downloaded kernel image given in friendlyarm website through USB.
After RESET, the system got stalled after the message on console "DONE, NOW
LINUX IS BOOTING"..........
2. I have tried re partitioning NAND flash and downloaded kernel image.
But NO positive RESULT
3. I found BIOS 2.0 in NOR flash instead of older version of BIOS as
mentioned in user manual. So, I tried to burn the older version of BIOS
into NOR flash
Doing so, I couldn't find SST39VF1601 option in SJF2440.exe menu. So,
please send the utility supporting this NOR flash to this email
ID(santforyou@gmail.com)
4. I also tried using H-JTAG V0.4.4. I succeeded in detecting the micro
controller but not the NOR flash(loaded script file given along with H-JTAG
in friendlyarm website)
5. Is this problem because of flash locking? If please send the solution
to my email ID(santforyou@gmail.com)
Please reply.
Regards,
Santosh,
Bangalore
problem while reburning bootloader
Hello when i flashed my board suddenly the power is gone and after reboot my board can not be booted from NAND and i always must turn the board to NOR and then press b to boot. when i boot from NAND it always show a message about USB boot on hyperterminal :( What can i do ?
try with porting of old version of vivi to nand insteadof supervivi....but it would not work with 128 mb nand as i m facing problem with it..
Hi I also have bought mini2440 boards from ebay sellers esky-sh and tekdevice I assume you have access to PC with Windows XP and printerport, these instructions are walid in such setup) the only way I got NOR flash SST39VF1601 programmed using the jtag cable that came with the boards is using HJTAG I am using version 0.9.1 version singe I dont use licensed software such as winrar and 0.9.2 requires winrar for extraction. If you download the 0.9.1 version, the following advise should work for you as it worked for me (and I could not get SFJ2440 work with my board that has Hynix NANDFlash) I used the hjtag macros that came with the board in H-JTAG folder along with a museum version of Hjtag (V0.4.4) the files are Friendlyarm2440.his and H-Flasher_mini.hfc things you need to do after installing hjtag and conecting the jtag cable: go to hjtag settings for lpt jtag change following stuff: User defined Pin assignments: TMS Pin4 D2 TCK Pin2 D0 TDI Pin3 D1 TDO Pin11 Busy nTRST not used nSRST not used pich up speed you suppose will work ( I use Max/2 in 2x2.5GHz dualcore PC) then you might see target changing after hitting ok if not, pick Detect Target from Operations submenu now you should see that target is ARM920T (this is correct, those sellers who claim it to be ARM926 are lying) Target ID should be showed as 0x0032409D now go to Scripts and load Friendlyarm2440.his (this file has address map of the board) now you can go to flasher (there is pulldown menu flasher, and there Start H-Flasher now the flasher is quite stupid, and you need to give it info about your flash (the beforementioned hfc file) you can now skip a bit to program wizard phase 5 and click Check it should result in information Flash SST39VF1601 0x234B00BF (or similar) and ARM920T Little endian If all went as i described so far, you can go to TYPE menu and select plain binary download and Destination address Flash base address then select SRC file (the ... is hidden button) I hope this is of help. Another thing: If your NAND flash is of make Hynix (instead of Samsung) , you NEED version 2.0 bios and probably even such that has length of 253K (older version is 127K) Esky-sh calls the file either supervivi-64M or supervivi-128M or supervivi_mini2440 (same as supervivi-64M)
flash locking can be unlocked from supervivi commandline (as opposed to supervivi menu) the command is flash unlock (flash help instructs : "flash unlock <start_addr> <length>" )
When I got my Mini2440 device, I thought it was great. However, I soon discovered I had version 2.0 of supervivi which doesn't correspond at all to the manuals I could find on the web or on the supplied cd. I was happy to find this forum. Everything in the above above post works great. The only problem is, after the flash, I get the error "No NAND device found!!!" when booting the NOR flash. Any help or thoughts on this could be greatly appreciated.
I am in a serious error with my mini2440 I am not able to reset my BIOS If i use SJF2440 it says Device ID didnt match Can anyone help me
dear all unfortunately i'm facing a similar problem. I have updated the nor flash supervivi with the HTAG tool. After the flash process has been finished I click on verify and the beeper started to make some terrible noise. After that I wasn't able to start the supervivi bootloader again (it only says NO NAND DEVICE FOUND). I've read an article about flash lock and a similar problem to mine, but therefore I would need the related FriendlyARM 2440.his and .hfc file to configure the init of the flashing (HTAG). Since I've got my board without any additional CD (containing all the corresponding data) I have to stop working here... Could anyone be so kind to post these necessary files. Or is there any other way to get this thing working again! Thanks a lot cheers
already working with newest supervivi but an older version does not work (still got same problem) probably therefore I would need the init config file!! thx anyway guys!
hey, thx for reply! no after installing (in my case) not depending on the version (4.4 - ..) of HTAG only the .hfc file is included (in newest v.) but .his file is missing!
Hi >> 1. I downloaded kernel image given in friendlyarm website through USB. >> After RESET, the system got stalled after the message on >> console "DONE, NOW >> LINUX IS BOOTING".......... Please check the u-boot machine ID and the kernel machine ID. They must be the same value. Regards
