Hello, There are multiple colors in the schematic of MINI2440. Some of the pins are red, some Green, What is the significance of the color? Thanks.
MINI2440 Schematics
Could you say which page and which document? I looked around what I think are the schematics for the mini2440 and can't see pins with those colours.
Good question. On the LCD connector it looks like the red ones are a supply voltage or should be a nominal high (nRESET). The green ones are either ground or should be a nominal low (LCD PWR). Purple ones on the GPIO connector is most likely just to highlight the SPI bus. My 2cents worth. HTH
