Hi guys is it possible to download to flash -uboot + kernel + file system using only USB DWN in Windows?I've read tutorials that use this method but for Linux Host environment.I tried the same on Windows and facing some trouble.I can download Uboot to RAM and get into it but NAND scrub isn't working .The control cursor doesnt stop for me to put yes 'y' or no 'n' .it says scrub aborted directly.Is it hapening coz doin it on windows ?? can anyone help me on this?
Uboot with Windows??
Kevin, You'll need terraterm (for serial console and xmodem) and solarwinds (http://www.solarwinds.com/products/freetools/free_tftp_server.aspx) tftp server. You can use the xmodem in terraterm to download uboot and use supervivi to write that into flash. When you reboot, you'll be running u-boot, and you can then tftp what you need to the target (using solarwinds tftp server). Windows as a host environment has no bearing on problems with scrubbing nand. Regards, gene
@sam -u r ryt .actually linux is quite new for me and i wanted a quick setup for reference on windows only. @gene thank u so muchfor the info
