Hi, I have some misunderstanding while understanding schematics, can any one please help me out. From mini2440_schematic_20100127.pdf *) What is cpu1.sch, cpu2.sch and cpu3.sch schematics.. i assume that cpu1.sch is a main cpu core having timer, clocks etc and remaining cpu2.sch and cpu3.sch are comes under soc (S3C2440)..am I correct..please correct me if am wrong... *)why 04-MEM.sch, 07-DM9000.sch, 05-UART_USB_POWER.sch, 08-INTERFACE.sch, 06-Audio.sch are separated any internal connection logic here..please let me know -- Thanks, Jagan.
Schematic howto
1) That is my understanding. 2) Those connections are printed circuit board connections, between the various ICs.
Yes. You are correct. It is what is known as a multiple hierarchy design in the electronics world. All the connections are interconnected via the NET NAMES. These are the names on the schematic lines that you can see. Because the processor is so large, it is broken down into "parts" to make it easier to work with. Even for small designs I tend to break it up into a multiple hierarchy layout simply to make it easier to read. For instance, I put power supplies on one sheet, connectors on another and processor on another. It also means you can print out the design on A4 or A3 instead of an expensive large format printer. :)
