Hi My board (128Mb)is having issues 1) When I put it it NAND mode it refuses to boot and to boot I have to switch to NOR mode and go Boot the system (b key) 2) After formating from supervivi and flashing the kernel and the rootfs no change same behavior as (1) 3) I noticed led1 is flashing and led 3 is always on, when in supervivi or otherwise. Any idea what is going wrong one hypothesis I had is there are bad NAND locks which have not been marked (no bbt) as bad hence the issues. Is there any I can mark the nand bad blocks after formatting, something like in u-boot ( nand createbbt) from supervivi or any other way to do it. OR Has there been a hardware failure ? regards --fatbrain
128Mb Hardware issues
Hi if you are using the Latest software (2010), you must update the bios-supervivi in NOR flash first. regards mindee
p7 of Mini2440 Downloader Instructions implies that bad blocks are managed by Supervivi. It certainly happens a lot faster then when using u-boot.
