Hi, we're using more than 50 mini2440 boards with W35i LCDs and sometimes (about once per week) the screen get randomly turned upside down (just the image, touchscreen works normally) and stays so until reboot. LCD is mounted in custom made metal case. We found out that shock from static electricity causes it (when somebody not wearing antistatic wearing touches it, it happens - again, only sometimes), so we power grounded the case and isolated it from display circuit, but the issue still remains. Does anybody encounter similar problem? Any ideas how to solve this? Thanks in advance
W35i screen randomly turning upside down
Some displays support two digital inputs to define the scan direction. Maybe one of these lines are floating and the display interprets it mostly correct, but sometime incorrect. Take a look into the data sheet of the used LCD and measure the voltage level at these lines at your display unit.
Also consider grounding the touch screen outer surface with a conductive material in your mounting. It will have to be a soft material that does not put pressure on the touch pad.
