hii,,, have default linux..n m first testing on it i HAVE TRY TO GET DATa FROM my PC(DNW) to friendly arm on its serial apps but m unable to do dat.. m gettin data sometyms but only the starting 2-3letters n when i transmit data from friendly its get recieve on DNW when i send commands of linux its repond on it..i guess only to prblm is with receive n printin..on friendly serial apps y its happening?? ny suggestions thanks in advance..
serial not working at receiving end TINY6410
Whgcih 2-3 letters do you get? Are you using the serial cable that came with the kit? Is DNW set at 115200 baud? Test in NOR mode (NAND/NOR switch) and every time you press reset the Mini will send the Supervivi menu. DO you use a RS232 to USB converter for serial to your host PC? Use "connect" on DNW every time you change a setting. The COM should show that baud as soon as you get a good connection,
hii, thnk 4 ur reply.. any starting 2-3 letters watever i send.. ya m using the same cable which came with the kit.. n DNW 115200 also.. NAND mode.. no,m using th cable from DB9..which is internally conneted to RS232 n m using COM0 which is console port..i tried using other port but dey r not getting connected ..cn help me gettin port connected??
