Hello guys, i have some problems with the RS232 on the mini2440 board. If i send something to the board i will only get garbage, but if my mini2440 sends to my pc everything is almost okay. Almost, because i need to connect the USB cable if i donīt connect the USB cable i will get garbage, too. I think its a problem with the shielding.....but if the USB and the seriall cable are connected i can receive from the mini2440 without a probem, but i can not send something to it. Any advise? b.t.w. i have tried 3 different PCīs and onboard and add on serial cards and a usb to com converter. Only my old hp notbook can connect and i only get some few transmition erros, but after all its untable too. I have checked the signal from my RS232 cards with my osciloscope it looks okay.
Anyone problems withe the RS232?
What bit rate do you use? Probably a lower bit rate solves your problem. With a 12 MHz crystal on board it's hard to meet the higher bit rates with full accuracy. If the mini2440 is 2% too fast and the PC 3 % too slow this can garble the communication ... sometimes in one direction only depending on the sampling algorithms of the UARTs. HTH
One thing that could clear up any frequency tolerance issues would be to get one mini2440 talking to another. 12MHz crystals would never be more than, say 100ppm off frequency (0.01%). You say the waveform looks O.K. Proper levels? Start bit and data bits all the correct length? Can you actually measure how long a data bit is (within +/-2%)? A general-purpose 'scope would not be able to do this. Decided to fire the FriendlyArm up and test it myself. Going to the serial assistant in Qtopia, selecting /dev/tty/SAC0, 9600 baud, 8 bits and filling up a few lines with the letter u and hitting the send button works in Hyperterminal with the supplied null modem cable. 115200 baud works as well. The letter u gives alternating highs and lows in the data stream, which might make it easier to tell if you are on frequency or not. The %error could vary with the baudrate chosen and a specific slow speed may not have the lowest error.
Thx for response, i have noticed that the cable is straight trough...thats stupid! i have used that cable to test my com ports today (i thougt it was a crossover) and now i have 2 defect com ports.. lol.. but i have also noticed that i have experienced grounding problems... i have solder a wire from gnd to the rs232 connectors shielding now it works with the comport of my 2nd pc! The next thing i do is changing the male connector against a female connector and than i can use a normal cable for the connection. A cable with 2 females is in most cases a null modem and its very hard to buy a cable here with 2 females as a stright through. My orginal cable is also damaged (contact problems) b.t.w. the serial card was a 180Euro expensive industrie card (opto insulated) , my stupidy makes me sad....
Finaly i got it! I have soldered my own cable. I have only use 3 pins: RX, TX and Signal Ground. (PIN; 2,3,5) as i have a opto insulated card i have not connected the chassis ground, and bingo it works. My RS232 card is still working i have spotted out that my cable was faulty and therefor i had these transission errors.. CU Andreas and thx for your help !
I encounter like that problem but I cant solved ,I also cant understand your solution...Andreas can you help me ?
I have the same Problem with my mini2440, I connect to ttySAC2 with mini connector, and have problems. With the same connector, the same cable ...., in my mini6410 work with no problems. Who knows something to solve the problem.... Thanks.
hi,
anyone can plz help me out with my problem,
the problm is
when i connecting my mini2440 with my laptop using usb-serial cable, my
console is not showing clearly, iam getting some values inbetween like
this...
�root@FriendlyARM /]#
%��ɥ��dlyARM /]�
[root@Fri����I5�/5�
[r�o|@Frien�lyARM /]#�
[�oot@FriendlyARM /]#
[r��ɥ���l�ARM /]#
�root@FrZY�I5�/]#
[roo�@FriendlyARM /]#
root�Fr�endlyARM /]#
[ro�@Friendlyx�
z�� �
[root�FriendlyARM /]#
[root@Friendl^P
z��
[root�Friendl^P�
z��
[roo�@FriendlyP�
z��
[roo�@FriendlyARM /]#�
+���ɥ��
5533;��I5�/]#
+���ɥ��d�yARM /]#
C�[root@FriY���I5�/]# H�[root
what should i do to rectify this problem... iam using /dev/ttyUSB0...
PLZ tell me solution....
