Accessing the path on a Windows CE device from another Windows CE device
fails, but accessing that path from a PC using desktop Windows does work.
My project.reg file is.....
; Copyright (c) Microsoft Corporation. All rights reserved.
; Use of this source code is subject to the terms of the Microsoft end-user
; license agreement (EULA) under which you licensed this SOFTWARE PRODUCT.
; If you did not accept the terms of the EULA, you are not authorized to
use
; this source code. For a copy of the EULA, please see the LICENSE.RTF on
your
; install media.
; Redirector settings
[HKEY_LOCAL_MACHINE\Comm\Redir]
; Expose \NETWORK dir for mapped resources
"RegisterFSRoot"=dword:1
; Set memory thresholds for Hibernate
[HKEY_LOCAL_MACHINE\SYSTEM\Hibernate]
"Bytes"=dword:20000
"Pages"=dword:28
IF BSP_DISPLAY_MQ200 !
; CS_SAVEBITS implemented. GWES restores screen bits on power on
; Options here are:
; 0 : OAL must deal with saving/invalidating bits between power on/off
; 1 : GWES will restore screen bits on power on
; 2 : Entire screen invalidated on power on
[HKEY_LOCAL_MACHINE\system\gwe]
"PORepaint"=dword:1
ENDIF BSP_DISPLAY_MQ200 !
; Let Start/Settings/Control Panel Auto Expand
[HKEY_LOCAL_MACHINE\Explorer]
"ExpandControlPanel"=dword:0
[HKEY_LOCAL_MACHINE\Windows CE Tools]
"Platform"="{c92d7f31-5ebc-4fb4-8a21-9a9f32633ba6}"
[HKEY_LOCAL_MACHINE\Ident]
"OrigName"="WinCE2"
"Name"="CEPC2"
[HKEY_LOCAL_MACHINE\Service\SMBServer]
"AdapterList"="*"
"dll"="smbserver.dll"
"keep"=dword:1
"Order"=dword:9
[HKEY_LOCAL_MACHINE\Services\SMBServer\Shares]
"UseAuthentication"=dword:0
[HKEY_LOCAL_MACHINE\Services\SMBServer\Shares\Windows]
"Type"=dword:0
"Path"="Windows"
"UserList"="@*;"
[HKEY_LOCAL_MACHINE\System\StorageManager\Profiles\MSFlash\FATFS]
"Flags"=dword:00000094
"FormatTFAT"=dword:1
"EnableWriteBack"=dword:1
"MountAsBootable"=dword:1
"MountAsRoot"=dword:1
I added above bold code to my project.reg file but same issue. (Accessing
the path on a Windows CE device from another Windows CE device fails, but
accessing that path from a PC using desktop Windows does work.)
When i check the Device name using settings it shows ---> Mini2440
But i changed the name in project.reg as "CEPC2" no use. (Not modified the
name, then manually change the name)
I tried remote admin also but no use...
Please suggest me any another solution for accessing a database to write
and read the data using two windowsCE 5.0 based boards.
