USB Drivers(64bit windows OS) for Friendly-arm supplied board is very bad. I had mini2440 since 2009, and till now I cannot find 64 bit USB drivers for that board, and it is same case with all the other boards. Recently I purchased TINY210 just seeing the specs, but after purchasing this board I realized that I have done mistake. I saw wince support is available for this board before purchasing this board, just purchased, but later found out i can only download image to device using crappy superboot.bin. I think majority of the customers using this board are hobbiest or someone who just want to learn about WinCE or androd/linux. and most of them are not going to use it for product development. And majority of people use a home laptop for learning purpose. As USB driver not available for frendly-ARM boards for 64 bit OS, we cannot use it for learning. In my case(kernel and driver development), I want use kernel debugging which is possible when Device Connects to the Visual Studio at boot time. And As USB driver and not available I cannot do it to connect to board for debugging purpose. However I can debug application using activesync over ethernet when device completely loads. I need to use these boards for learning Driver development, and not for application development. frendly-ARM needs focus on providing basic infrastructure for debugging and downloading first than just adding fancy MP4 decoder stuffs. When most of the laptops have unused LAN port, which can be used for kernel debugging, instead of USB driver, why not just use that. I initially thought that I can add support for bootloader and ethernet, but I dont have JTAG bebugger (Exdi interface) to connect to the Device for bootloader debugging, and without it is very difficult to debug just using serial debug messages. I recently purchased TI Beaglebone(ARM cortex a8 processor) and I was able to port the BSP. I used EVM335x Reference BSP and ported to Beaglebone. It was because they had eboot with ethernet support. So I can Hook up device to the spare ethernet port. So, I request friendly arm to provide eboot software over ethernet instead of USB. and also superboot, we dont need it. Thanks,
MINI210/TINY210 bootloader on ethernet instead of USBRNDIS
You need to learn to search better, there is definitely a 64bit drivers for the mini2440. The majority of customers aren't hobbyists, they're OEM, we're just a small fraction of the customers for these boards. You could however write your own u-boot port or similar, which is generally what hobbyists end up doing if the manufacturer/supplier won't do it for you. I'm still not sure what usb will give you over jtag, why don't you just purchase the correct tools for the job? You're happy to spend $150 on a board but not $20-30 on the tools that will allow you to develop more on it and probably all of the other boards you might own.
@reggie Are you sure majority of customers are OEMS?.. and what is the problem in having eboot instead of superboot for mini210, the standard Microsoft bootloader for WInCE os. If you dont understand why we need USB and Jtag support. Please do a proper research before commenting.. For debugging WinCE platfporm using Jtag we need EXDI interface(software), for that i think most of Cheaper Jtag dont have support. I have Jlink and Ulink and Parallel Jtag, unfortunately cannot use it, as they dont have Exdi interface. Assume I am writing a Kernel mode driver for Windows Ce and I want to load it at Boot time, I cannot debug as my USB driver over which Kernel debugger is connected for debugging purpose. @reggie Tell me Where is 64 bit USB driver for Mini2440, that i can use for downloading and also debugging over platform builder. If you managed to find is please post it in forum so that every one is benefited. I dont want to use uboot..
http://code.google.com/p/supervivi-transfer-tool/downloads/detail?name=S...= And yes, I'm very sure that most of their customers are not hobbyists :-)
@Reggie I am aware of this tool its for MINI2440, you can download OS image using USB, but cannot be used for debugging and using Kernel Debugger. As i mentioned earlier that without using kernel debugging IT is very difficult to debug the WinCE drivers. We can use serial output but it is very time consuming process. sometime you just want to breaking and watch registers or call stack. It is very hard to achieve, using serial debug. For mini210 there is no 64 bit drivers. I was suggesting as DM9000 eboot drivers are already available in davicomm website, so why not just integrate it with eboot and give us. Once Bootloader is working (eboot), then things will be easy for us. When Wince Image loads the KITL inteface is up and KDBG(Kernel debugger) is up and running we can just do any debugging. We can even break in Kernel loading. So you can say If someone wants to work in WinCE, the KDBG is mostneeded. It can be up by JTAG or KITL(Ethernet or USB or serial). Once KITL communication is up we can use some of the powerful tools like KernelTracker, CELog etc to debug drivers. As you know friendlyarm is not only cheap development kit. Recently I heard RASPBERRY PI ($35) will also get WinCE 7 OS(http://bolingconsulting.com/2012/i-have-a-new-raspberry-pi/).There are other powerful and Cheaper boards in the market like BeagleBoard and BeagleBone, they provide STEPLDR and EBOOT Binaries that we can use to connect to Platform Builder. As BSP for these boards are not open source, still we can port the Reference BSP to these boards by using the binaries. As stated earlier to debug WinCE OS using PlatformBuilder we need exDI interface, and It is available with few expensive debuggers like lauterback or RealView ICE. They cost a lot. And Tiny210 there is no JTAG interface available. So Jtag option is ruled out. Integrating Ethernet drivers should not be hard, FriendlyARM (www.ARM9home.net) are using Trace32 (lauterback) for debugging purpose, so it will not be hard for them. So, If any moderator reading this post I request you to provide Ethernet boot-loader, so that I will help more and more people like me to develop new things for these community boards.
