I have a mini2440 with 7" LCD. I have the "mini2440_defconfig" home built kernel with debian on my system and im trying to get qtopia running (more or less in the same way as on the default image). when i boot i see the logo and then i can start qtopia but after a while the screen just blanks out. Perhaps the backlight turns off or something? because the systems seems to be still running. I guess its some sort of power saving, but how do i activate the screen again?
LCD screen blank after a while
The "problem" was that i have tty1 pointed to the LCD with a console login on. And then the standard screen blanking got activated after a while. There are probably a couple of different solutions to this but i added: setterm -blank 0 > /dev/tty1 to startup and it worked. /Erik
Can I ask a more basic question? What Linux commands do you use to point tty1 to the LCD? And can you then send text and graphics by direct copying? Thanks in advance.
