When building the mini6410 OS, the build sequence fails in two areas. First, it fails to load the .pbxml file that, in fact, is in the path the builder was looking at. Second, the "Tools Install Dir in registry is missing" message appears. What do I need to do to correct these issues so it will have a successful build? ------ Build started: Project: OSDesign_1_2_2012, Configuration: Samsung_SMDK6410 Debug Platform Builder (_TGTCPU) ------ Starting Build: blddemo -q ============== BLDDEMO: Generating OS Design Folders Failed to load C:\WINCE600\OSDesigns\OSDesign_1_2_2012\OSDesign_1_2_2012\OSDesign_1_2_2012.pbxm l: Tools Install Dir in registry is missing. BLDDEMO: Done Generating OS Design Folders BLDDEMO: Generating OS Design Files to C:\WINCE600\OSDesigns\OSDesign_1_2_2012\OSDesign_1_2_2012\Wince600\SMDK6410_ARMV 4I\oak Failed to load C:\WINCE600\OSDesigns\OSDesign_1_2_2012\OSDesign_1_2_2012\OSDesign_1_2_2012.pbxm l: Tools Install Dir in registry is missing. BLDDEMO: Done Generating OS Design Files CEBUILD: Deleting old build logs CEBUILD: Skipping directly to SYSGEN phase Building dep trees: winceos dcom gdiex ie script servers shellsdk shell rdp wceshellfe wceappsfe directx voip datasync netcfv2 netcfv35 sqlcompact SQLCE cellcore ostest mediaapps speech FP_VOIP OSDesign_1_2_2012 CEBUILD: Running sysgen preproc (for COMMON) Starting sysgen phase for project ( common )
