Hi All, I'm using the bsp from pengutronix. All seems to work after following the mini2440 quickstart manual. I've enable the http server in busy box. It runs and i can connect to it and after creating a html file in /home/www i can view it with a browser. Now I want to add some default html files in the map /home/www and build the filesystem. I put the files in <bsp folder>/configs/platform-friendlyarm-mini2440/projectroot/home/www. But they will not show up in the created rootfs after running the command ptxdist images Can anyone tell me how to do this ? Should I really follow the (quite complicated) chapter 8.26 in the quickstart guide, or is there an easier way ? Gene
pengutronix add custom files to rootfs
Once you have followed the procedure in section 8.26 your life will be made
significantly easier!
I have done some more recent work with these files using the install_tree
macro and that has made things an order of magnitude easier. You just drop
your files into a folder, ie /home and everything is handled automagically.
daves_rootfs.in
## SECTION=rootfs
menuconfig DAVES_ROOTFS
bool
prompt "files in dave's rootfs "
help
Dave's special files to make his target work
if DAVES_ROOTFS
config DAVES_ROOTFS_MSMTPRC_DAVE
bool
prompt "install /usr/local/etc/msmtprc-dave"
help
If enabled, it installs the "./projectroot/usr/local/etc/msmtprc-dave"
file if present.
config DAVES_ROOTFS_MSMTPRC_CHARLES
bool
prompt "install /usr/local/etc/msmtprc-charles"
help
"./projectroot/usr/local/etc/msmtprc-charles" file if present.
config DAVES_ROOTFS_LIB_UDEV_RULESD_TTYACM0
bool
prompt "install /lib/udev/rules.d/50-udev-default.rules"
help
"./projectroot/lib/udev/rules.d/50-udev-default.rules"
file if present, else a generic one from the ptxdist directory.
config DAVES_ROOTFS_INTERFACES
bool
prompt "install /etc/network/interfaces"
help
If enabled, it installs the "./projectroot/etc/network/interfaces"
config DAVES_ROOTFS_NANORC
bool
prompt "install /etc/nanorc"
help
If enabled, it installs the "./projectroot/etc/nanorc" file if present.
config DAVES_ROOTFS_NANORC_SCRIPTS
bool
prompt "install (PTXDIST_WORKSPACE)/projectroot/usr/share/nano/*"
help
If enabled, it installs the "./projectroot/usr/share/nano/*" files if
present.
config DAVES_ROOTFS_MY_HOME_FILES_AND_DIRECTORIES
bool
prompt "install (PTXDIST_WORKSPACE)/projectroot/home/*"
help
If enabled, it installs the "./projectroot/home/*" files and
directories if present.
endif
daves_rootfs.make
# -*-makefile-*-
# Copyright (C) 2002, 2003 by Pengutronix e.K., Hildesheim, Germany
# 2009 by Marc Kleine-Budde <mkl@pengutronix.de>
# (C) 2010 by Michael Olbrich <m.olbrich@pengutronix.de>
# See CREDITS for details about who has contributed to this project.
# For further information about the PTXdist project and license conditions
# see the README file.
# We provide this package
PACKAGES-$(PTXCONF_DAVES_ROOTFS) += daves_rootfs
# dummy to make ipkg happy
DAVES_ROOTFS_VERSION := 1.0.0
# Target-Install
$(STATEDIR)/daves_rootfs.targetinstall:
@$(call targetinfo)
@$(call install_init, daves_rootfs)
@$(call install_fixup, daves_rootfs,PRIORITY,optional)
@$(call install_fixup, daves_rootfs,SECTION,base)
@$(call install_fixup, daves_rootfs,AUTHOR,"Dave Festing
<dave_festing@hotmail.com>")
@$(call install_fixup, daves_rootfs,DESCRIPTION,missing)
# my install_alternative/install_tree files and directories
ifdef PTXCONF_DAVES_ROOTFS_MSMTPRC_DAVE
@$(call install_alternative, daves_rootfs, 0, 0, 0644,
/usr/local/etc/msmtprc-dave)
endif
ifdef PTXCONF_DAVES_ROOTFS_MSMTPRC_CHARLES
/usr/local/etc/msmtprc-charles)
endif
ifdef PTXCONF_DAVES_ROOTFS_LIB_UDEV_RULESD_TTYACM0
/lib/udev/rules.d/50-udev-default.rules)
endif
ifdef PTXCONF_DAVES_ROOTFS_INTERFACES
/etc/network/interfaces)
endif
ifdef PTXCONF_DAVES_ROOTFS_NANORC
@$(call install_alternative, daves_rootfs, 0, 0, 0644, /etc/nanorc)
endif
ifdef PTXCONF_DAVES_ROOTFS_NANORC_SCRIPTS
@$(call install_tree, daves_rootfs, 0, 0,
$(PTXDIST_WORKSPACE)/projectroot/usr/share/nano, /usr/share/nano)
endif
ifdef PTXCONF_DAVES_ROOTFS_MY_HOME_FILES_AND_DIRECTORIES
$(PTXDIST_WORKSPACE)/projectroot/home, /home)
endif
@$(call install_finish, daves_rootfs)
@$(call touch)
# vim: syntax=make
Notice the install_tree directive. Read about this in the
OSELAS.BSP-Pengutronix-Generic-arm-Quickstart.pdf
Thanks Davef Did copy your files and edited it for my needs and it works. My life is indeed significantly now (at least for updating the rootfs ;) ) Thanks, Gene
I am going to do another install_tree macro for /etc as that seems to be another directory that multiple user files ends up in. ifdef PTXCONF_DAVES_ROOTFS_MY_ETC_FILES_AND_DIRECTORIES @$(call install_tree, daves_rootfs, 0, 0, $(PTXDIST_WORKSPACE)/projectroot/etc, /etc) endif Yes. it made the rootfs easy to update to a later BSP. Cheers, Dave
