what is s3c2440 maximum gpio io pin speed in mhz . i need gpio speed. not cpu core speed.
s3c2440 maximum gpio speed
You didn't try very hard. I type GPIO SPEED into search and found your question and these other 2. http://www.friendlyarm.net/forum/topic/3566 http://www.friendlyarm.net/forum/topic/3476
Why don't you write a little bit of code with the OS you have to simply toggle a GPIO pin on and off in a loop. You can then measure this with a scope and get the value you need.
Your question is a little hard to answer for simple reasons. You don't specify which OS you will use or if it will be OS free. You don't specify what sort of speed you want to get out of the device. What is the application you are going to use this for?
thank you very much Dave McLaughlin. i will use s3c2440 OS free. i will write my own code . i want to interface s3c2440 with high speed ADC. for making oscilloscope :) .
hi i am using samsung s3c2440 board . can anybody tell me which port they have given as a GPIO(34 pin) in this board ? we have 130 pin io pins and ports from A,B......to ..H . in whic port we can use from 34 pin GPIO?
Ahmed, if your scope requires speed, the commercial ones I have seen use FPGA's to do the real time sampling. Asking a processor to do this in software means your scope is basically going to be low speed. Anyway, how does GPIO speed work with your ADC? Are you going to bit bang SPI or something along those lines? Surely the built in SPI port would be fast enough. What sort of speed of scope are you planning on building?
