Hi, I want to install Android on a mini2440 device. But I dont want to lost current linux configration. How can I backup this all working current configration then for install again back. thanks a lot.
Backing up all device.
hi, just use the supervivi's "u" fuction to backup the whole Nand flash as a image file. regards mindee
As far as i know DNW tool only supports tranmitting files to mini2440. Which version of DNW are you using mindee?
My version is 0945-2K [u] Backup NAND Flash to HOST through USB(upload) [r] Restore NAND Flash from HOST through USB
I guess you got me wrong. I was not asking you supervivi version. Both DNW 0.50A and 0.50L(wince) versions does not have an option to receive nand dump from supervivi [u] function. I should have asked how you were able to receive nand backup after selecting [u] from the supervivi menu.
Sorry, my fault. Didn't read your post properly. Hmmm, never noticed that DNW only has an RX Test...
You must use the FriendlyARM version of DNW: http://www.friendlyarm.net/dl.php?file=dnw.zip
Thanks Tom. Eventough this DNW also has the version 0.50A (funny : some people has problems assigning version) it has options to backup and restore.
