Hi, I just received a batch of Tiny210 modules and discovered that my NK.bin doesn't work. I'm still to get to the bottom of it but after looking over the module I see the PCB revision is the same but the most obvious difference is that the Nand Flash chip has twice the capacity of my earlier ones. My original ones were 256MB but the new ones are 512MB. Anyway - my assumption is that the NandFlash.dll needs to be updated with the correct parameters for the new flash chip. But since there's no source for this we can't do this ourselves. Does anyone have a working Wince 6 on the 512MB version of the Tiny210? Some of the other BSP's floating around for the same processor do have source for the nand flash driver so I may have to try and obtain one of these and see if I can get it to work. I'm currently using the Tiny210-20120913 version of the supplied FriendlyArm software.
Tiny210 512MB version
I would buy one if the 512 with 7"capacitive touch running CE7 in a flash. Anyone know if this will ever happen ?
OK, so the problem is definitely the change in Flash memory size. Does anyone have the actual source for the nandflash driver? Note that the files are in the BSP but if you try to build them they don't build due to errors. FriendlyArm provide us the Nandflash.dll in the FILES folder and have the Nand source excluded from the build so they must want to keep the source for the driver closed.... If anyone has a working version of the source even if it's for the 256MB version I'd be most interested in seeing it. Shouldn't be hard to modify for the 512MB board.
Download the new BSP from the followe website: http://armdevs.com/info194.html The new update for the Mini210/Tiny210/Tiny210V2 for WiNCE in 2012-11-16: Update Detail:Support 512MB Nand Flash and Capacitive screen in WInCE 6.0 Update Date: 2012-11-16
Unfortunately this does not work. I think the issue is that the Nandflash driver in the new BSP has been updated to support the new Flash memory but has some bugs in it. It does recognise the larger flash chip yes, but it reports the wrong size to the OS. Here is a dump of the debug build of Mini210-en (using the new Mini210 BSP from 16/11/2012 - 1246 ) I think the issue is shown in the line "FSDMGR!StoreDisk_t::Mount: Geometry: NumSec=-79 BytesPerSec=1 FreeSec=0 BiggestCreatable=0" where it reports a negative number for the number or sectors and also 1 bytespersec. FSDMGR!PNPThread: Using PNPUnloadDelay of 4096 NandMlc2Probe: 0 FSDMGR!StoreDisk_t::OpenDisk (0xD0045060) DeviceInfo Class (0x00000001) Flags (0x00000005) Type (0x00000002) Profile (NANDFLASH) FSDMGR!MountStore: Attaching new storage device "NANDFLASH"FSDMGR!DumpRegKey: Dumping registry for key System\StorageManager\Profiles AutoMount = 00000001 AutoPart = 00000000 AutoFormat = 00000000 MountFlags = 00000000 DefaultFileSystem = PartitionDriverName = MSPART Folder = Mounted Volume ActivityEvent = PowerManager/ActivityTimer/SystemActivity FSDMGR!DumpRegKey: Dumping registry for key NANDFLASH Name = NANDFLASH DefaultFileSystem = FATFS PartitionDriver = flashpart.dll Folder = NANDFlash AutoPart = 00000001 AutoFormat = 00000001 AutoMount = 00000001 MountFlags = 00000000 MountAsBootable = 00000001 FSDMGR!StoreDisk_t::GetPartitionDriver: Using the generated partition driver name (flashpart)!!! Kernel DLL 'flashpart.dll' needs thread creation/deletion notification FSDMGR!LoadPartitionDriver: Loading partition driver flashpart.dll hModule=9FF7AE40 FSDMGR!StoreDisk_t::Mount: Opened the store "NANDFLA" hStore=0xD0046180 FSDMGR!StoreDisk_t::Mount: Geometry: NumSec=-79 BytesPerSec=1 FreeSec=0 BiggestCreatable=0 Exception 'Data Abort' (4): Thread-Id=00600002(pth=9ffc0678), Proc-Id=00400002(pprc=83799aa0) 'NK.EXE', VM-active=0040000FSDMGR!PNPThread: PNPThread starting! 2(pprc=83799aa0) 'NK.EXE' PC=c0689f34(flashmdd.dll+0x00029f34) RA=c0689eb8(flashmdd.dll+0x00029eb8) SP=d00be2a4, BVA=d0241000 FILESYS: Starting boot phase 1. FSDMGR!STOREMGR_StartBootPhase BootPhase=1 (PrevBootPhase=0) FSDMGR!AutoLoadFileSystems: CurrentBootPhase=1, LoadFlags=1 FILESYS: Starting device and waiting for boot file system. *** DLL_PROCESS_ATTACH - Current Process: 0x42, ID: 0x400002 *** Filesys: Loaded device.dll FILESYS: Waiting for device manager to signal BootPhase1 completion. +InitDeviceFileSystems FSDMGR!MountTable_t::RegisterVolumeName: Registered "$device" at index 5FSDMGR!MountTable_t::RegisterVolume: Registered volume at index 5 (Name="$device", MountFlags=0x1)FSDMGR!MountTable_t::RegisterVolumeName: Registered "$bus" at index 6FSDMGR!MountTable_t::RegisterVolume: Registered volume at index 6 (Name="$bus", MountFlags=0x1)-InitDeviceFileSystems: status is 1 Ceddk!CalibrateStallCounter: Enter Ceddk!CalibrateStallCounter: Could not find stall counter Ceddk!BeginCalibration: min(12001) max(13334) Ceddk!BeginCalibration: Elapsed is 13296 Ceddk!BeginCalibration: Delay is 97 DEVICE!DevloadInit DEVICE!InitDevices: Root Key is Drivers\BuiltIn. DEVICE!RegReadActivationValues RegQueryValueEx(Drivers\BuiltIn\Prefix) returned 2 DEVICE!RegReadActivationValues RegQueryValueEx(Drivers\BuiltIn\BusPrefix) returned 2 DEVICE!RegReadActivationValues RegQueryValueEx(Drivers\BuiltIn\NANDFLASH\BusPrefix) returned 2 DeviceFolder::LoadDevice(Drivers\BuiltIn\NANDFLASH) last 8 TicksDEVICE!RegReadActivationValues RegQueryValueEx(Drivers\BuiltIn\Drvlib\Prefix) returned 2 DEVICE!RegReadActivationValues RegQueryValueEx(Drivers\BuiltIn\Drvlib\BusPrefix) returned 2 DMSG: DrvWAITInitialize + NKKernelLibIoControl - NKKernelLibIoControl Kernel DLL 'drvlib.dll' needs thread creation/deletion notification DEVICE!CreateDevice: illegal entry point combination in driver DLL 'drvlib.dll' CreateDevice: creation of type '<unnamed>', index 0, lib 'drvlib.dll' returning 0x00000000, error code 1 DEVICE!I_ActivateDeviceEx: couldn't activate: prefix <nil>, index 0, dll drvlib.dll, context 0x1 DeviceFolder::LoadDevice(Drivers\BuiltIn\Drvlib) last 55 TicksFILESYS: Waiting for bootable file system to be mounted. FILESYS: Waiting for bootable file system to be mounted. FILESYS: Waiting for bootable file system to be mounted. FILESYS: Waiting for bootable file system to be mounted. FILESYS: Waiting for bootable file system to be mounted. FILESYS: Waiting for bootable file system to be mounted. FILESYS: Waiting for bootable file system to be mounted. FILESYS: Waiting for bootable file system to be mounted. FILESYS: Waiting for bootable file system to be mounted. FILESYS: Waiting for bootable file system to be mounted. FILESYS: Waiting for bootable file system to be mounted. FILESYS: Waiting for bootable file system to be mounted.
Download the Wince system image with the follow website: http://armdevs.com/info194.html Notice, the superboot.bin in the SD card and the the board need to update with the new verison. You can download our system image file to update it with your 512MB flash.
Yes it was the SuperBoot update that was needed. Yesterday when FriendlyArm gave me the updated BSP I wish they had given me the updated SuperBoot file at the same time. It would have saved lots of time! Thank you for helping me out so quickly.
