After receiving it last week, I've just had a chance to power up my latest mini2440, thought I'd post the details from the bootup. s3c2440-nand s3c2440-nand: Tacls=3, 29ns Twrph0=7 69ns, Twrph1=3 29ns NAND device: Manufacturer ID: 0xec, Chip ID: 0xf1 (Samsung NAND 128MiB 3,3V 8-bit) Scanning device for bad blocks Bad eraseblock 241 at 0x000001e20000 Creating 4 MTD partitions on "NAND 128MiB 3,3V 8-bit": 0x000000000000-0x000000060000 : "supervivi" 0x000000060000-0x000000260000 : "Kernel" 0x000000260000-0x000040260000 : "root" mtd: partition "root" extends beyond the end of device "NAND 128MiB 3,3V 8-bit" -- size truncated to 0x7da0000 0x000000000000-0x000040000000 : "nand" mtd: partition "nand" extends beyond the end of device "NAND 128MiB 3,3V 8-bit" -- size truncated to 0x8000000 Don't know if its my imagination, but it appears to boot faster than the 64MB version.
128MB Memory mini2440
Is it possible, just to replace the NAND chip on the board, to get the 128MiB Flash or do I need to modify some other things?
I have read somewhere that it is not advisable to replace the NAND, because the traces come off easily even with tools. If you want to boot a bigger image (android: >64MB) it is possible to boot from SD. I forgot the link, where Ive read it.
