Hello Anyone have a working "VNUWLC6.dll" for WindowsCE6r3 on Mini6410. Every one I find just keep asking for driver location, if I select some of the new 1.74 or older x86 than just gives me error loading driver.
VT6656_VNUWLC6 Driver
I need your help please, cannot make 1.70 or 1.74 driver to load, wince asking for driver location, no mater which version I select it will just ask again. Followed precisely the instruction provided int the text file, no luck, all my Monthly update is valid from MS, build 4-5 os image with default and some modified setting, no change. Please upload you driver if you got one working.
Can you guys look in your projects folders to see that maybe you have a working version of this driver. Thank you.
No go on installing driver VT6656_ce6_v1.70_mx27.zip Download new bsp, followed step by step instruction, build new os. Any suggestion. http://i.imgur.com/1tjXv.jpg
If I unplug the usb adapter than the driver load but will unload in a few second later. The adapter work fine with windows xp. http://youtu.be/xBUG4b1_wg8
