Hi, I have ported Pengutroncs bsp in mini2440 successfully with linux 3.1. But after implementing I am not able to control CON20 - GPJ port from kernel/userspace, I don't know why? Before with Friendly arm BSP with linux 2.6.32.2 I was able to control CON20 - GPJ port from kernel/userspace? In my simple driver I am trying to write value on GPJ port using __raw_writel, but no luch, however same thing happen for GPF port. __raw_writel(0x000000, S3C2440_GPJDAT) - not working - GPJ port remains high __raw_writel(0x000001, S3C2440_GPFDAT) - working - GPF port value is now 1 @Juergen, can you please help me out there...? Its urgent.. !!
Pengutronics - Camera Interface - CON20 - GPJ not working
From where should I configure this GPIO to act as GPIO? from my driver
itself?
If so, how can I configure this pin to act as gpio?
s3c2410_gpio_cfgpin(S3C2440_GPJ0,S3C2440_GPJ0_OUTP), but S3c2440_GPJ0 is
not defined in kernel 3.1.
How do define S3C2440_GPJ0? in older kenel it was defined in
/arch/arm/mach-s3c2410/include/mach/regs-gpioj.h as #define S3C2440_GPJ0
S3C2410_GPIONO(S3C2440_GPIO_BANKJ, 0)
Please guide me right direction, so that I can use GPJ port as GPIO !!
For example in this way: gpio_request_one(S3C2410_GPJ(<X>), GPIOF_OUT_INIT_HIGH, <usage of X>); e.g. use the generic gpiolib to manipulate the GPIO in a correct and managed manner from inside the kernel.
@Juergen,
I want send data to whole GPJ Bank using __raw_writel, however the same
thing working pergectly for GPF bank using __raw_writel method inside the
kernel.
I was able to drive GPJ bank in 2.6.32.2, but somehow I am not able to
control it from kernel.
int i,ret;
for (i = 0; i < 13 ; i++)
gpio_request_one(S3C2410_GPJ(i), GPIOF_OUT_INIT_HIGH, "For X");
I did this thing in driver for initialization, now when I try to send data
on GPJ,only GPJ0 pin takes effect, all other pin remains low. i.e. no
effect on other pin.
I have also tried the same thing from user space, but GPJ is not operating,
but GPF is operating.
I don't know what is wrong over here.
@Juergen, This comment is defined in regs-gpio.h. /* The S3C2412 and S3C2413 move the GPJ register set to after * GPH, which means all registers after 0x80 are now offset by 0x10 * for the 2412/2413 from the 2410/2440/2442 */ Do i need to check with offset 0x10 instead of 0x04, because in kernel 2.6.32.2 i used to do __raw_writel(0x0000011, base + 0x04), so that offset was 0x04. Please let me know in details.
You have to follow the S3C2440 data sheet and keep in mind the hardware registers are accessible only via a virtual address. First test with the gpio lib API, and if it works, change back to your own method.
@Juergen, I am following the standard way to drive GPIO, as it was working perfectly with older kernel 2.6.32.2 with BSP from Friendly ARM. It will be great If you can provide example of PWM, LED control in Pengutronics BSP. As of now other GPIO are working from the kernel space but GPJ is not working. As in my previous post there is a comments in regs-gpio.h file about offset. My only question is only GPJ port is not working this way. Could you please try operating GPJ port from the kernel module with recent kernel and tell me If I am doing something wrong over here? Thank you for your time in advance.
@Juergen, Any updates on accessing GPJ port using Pengutronics BSP? I really needed help from you. OR can you please share me an example of operaing gpj port using address/driver? Look forward to hear from you soon.
@Davef, @Juergen, I am trying to get GPJ port working as you know, If I try to get base of GPJ port using below line I am getting kernel error while sending data to GPJ port. void __iomem *base = S3C2410_GPJ(0); Unable to handle kernel NULL pointer dereference at virtual address 00000104 If I am trying to get base value is below line, GPJ port is not working. void __iomem *base = S3C2440_GPJCON; Please help me to get GPJ port working with Pengutronics BSP with linux-3.1. Are you guys on holiday or something? Please help me, I really need this. OR let me know If linux-2.6.32.2 is working with Pengutronics BSP. I have tried but seems like kernel is not finding correct partition. Look forward to hear from you soon.
miniarm, I have been away building a house. I not have experience with what you are trying to do. I do recall a previous thread where someone else was trying "to get direct access to memory" and from what I could understand this was a "difficult procedure". I would not even try to get 2.6.32.2 to work with the Pengutronix BSP. Stick to their packages, at least they have been tested. Good luck!
@davef, If I am trying to do telnet I am getting following error. Trying 192.168.1.167... Connected to 192.168.1.167. Escape character is '^]'. Connection closed by foreign host. with this error, telnetd process stop/kill inside the board. Don't know why?
Hi, Finally, able to set GPJ port using Pengutronics BSP from user space. I am still not sure this patch help me or not. http://lists.infradead.org/pipermail/linux-arm-kernel/2010-March/010698.... But I configure GPJ port in kernel space and I am able to operate from user space, also verify voltage with Multimeter for all GPJ pin. Thanks all for your time and consideration.
hi i am using pengutronics BSP can i can i able to interface the wireless video camera??? if possible send some references.... Thanks in advance
Depends on the wireless adapter you are using at the Mini2440 side to receive the data from the camera.
