Hi srs, I have already designed my own wince6.0 image and it is running on tiny 210 device. Then I have installed my own application (developed i visual studio 2008, visual basic) and SQL server compact 3.5, but when I switch device off, both applications are not in program files folder. When I reset the device by reset switch, applications are in the folder. Do you know what is wrong? Thanks in advanced.
Application disappear after turn off S1 switch
It's memory based system. Hive-based or rom-based. You will need to build your own BSP in order to fix this. I think they have it so that it clears out and defaults each hard bootup.
