Hi,please help me to know how can i using my mini6410 board without adaptor and by battery ?
How Can I use Battery for Power in mini6410 borad
If you use a Microchip MCP73781 this will do the battery charging and also use a DS2745 to monitor the charging via I2C. This is a nice IC as it automatically switches the supply from battery to charging input and at the same time charges the battery. You then need to build a buck/boost power supply that can take the battery voltage and generate 5.0V output from around 2.7 to 4.2 input. Check out the TP63020 from Texas for a suitable switching supply IC. Depends on your Mini6410 and what size LCD you are using but I would make sure the supply is at least 1.5A output. This can be charged from USB or from a wall power supply with 5V output. Dave...
