I need 'dd' linux command for made a boot sd. I have a coplet linux system on board mini2440 but there i not a 'dd' command. an idea to remplacing 'dd' with an other command ?
mini2440 and SD card
I have always used 'dd' on the Linux host, but not on the target. I would expect that one could enable that function in a custom version of Busybox or coreutils. Both of these can be enabled in the Pengutronix's BSP.
Thank you very much to have answered me. I built my system with BSP Pengutronix. How to validate dd? With ptxdist?
ptxdist menuconfig -> Shell & Console Tools -> busybox -> Coreutils -> [*] dd But to deploy an SD card you should use some USB based SD card reader and write all required data from your host to this card (as davef already recommended).
I noticed the document quoted here: 'http://www.friendlyarm.net/forum/attachment/15363 '. In this document, we have: mkfs.ext3-Lroot /dev/mmcblk0p2. In my file env/config, ext2 is used for mmcblk0p2. What do I have to do?
